Firmware & editor version 5.1.0 are now available!
FEATURES:
TO UPDATE FIRMWARE:
-OR-
Firmware: https://www.rjmmusic.com/downloads/PBC/MM510.zip
Mac Editor: https://www.rjmmusic.com/downloads/PBC/MastermindEditor-5.1.0.dmg
PC Editor: https://www.rjmmusic.com/downloads/PBC/MastermindEditor-5.1.0.zip
PBC/6X Manual: https://www.rjmmusic.com/downloads/PBC6X/PBC6X Manual-4.3.pdf
PBC/10 Manual: https://www.rjmmusic.com/downloads/PBC/PBC Manual-4.2.pdf
FEATURES:
- New device support:
- Amplitube Tonex
- Chase Bliss Mood 2 & Gen Loss 2
- Flower Sunflower
- Strymon Brig, Cloudburst and Ultraviolet
- Added new Bank Size parameter, which allows you to set a fixed bank size. This is the amount of presets the Bank Up and Bank Down advance through the preset list. (This has no effect in Song & Setlist mode.) The default value "Auto" is the old behavior, where bank size is determined by the number of preset buttons on the current page.
- Corrected the default settings for the Axe-Fx III looper button
- Improved the way log taper compensation works in expression pedals, expression pedal bar graph also works better when using log compensation
- Fixed issues in the setup menus relating to the "clear" button
TO UPDATE FIRMWARE:
-OR-
