how did you get up the hold function like that with the red remote?It can using the function jack. I do it with a Kilt V2 on my PBC 10. You just run a TS cable (if you have a second pedal to control, you can use a TRS > 2x TS split cable) to the red jack. The feature is then triggered using the function switch feature in the PBC. Personally I have mine set up so that a quick tap activates the loop my Kilt is in, and a long press triggers the function switch and turns on the fuzz mode on the kilt.
Set up as the Hold function on a normal IA switch.how did you get up the hold function like that with the red remote?
