Many apologies if what follows is an obtuse question.
Do you need an effects loop on your amp(s) for the RG-16 to function properly with the following setup? -->
Amp 1: Mesa Boogie 3 Channel Dual Rectifier (has FX loop)
Amp 2: Divided by 13 JRT 9/15 (does not have fx loop)
I only have pedal-effects, no effects processor.
I run my guitar through a bunch of pedals and then into a Lehle amp switcher so that I can use the same pedals for both amps.
Thus, is it fine to use the RG-16 to create loops for my pedals, and then run the RG-16 into my Lehle amp switcher so that the effects connected to the RG-16 are usable on both amps?
I realize this is moot if I need an effects loop in Amp 2.
