I was just going to ask about this...
I've setup my LT to "resend" on preset 2nd press and set each of my cba pedals in devices to send redundant PCs to on.
This way I just hold down both buttons on the cba pedal and press the current preset.
It would be nice if there was a "send current pc button"
@rjmmusic is there a way to program a button to resend the current pc number to a device?
Not currently, I'll try to get that into the next non-bug fix release.
Isn't this what "Send redundant PCs" achieves?
Yes it does, however I would like a separate option to do so. Send redundant pc causes issues while playing live... it reloads the current preset which causes the brothers to briefly cut out
Ok, I think I figured this thing out. So, if I want to save a preset on the tonal recall pedal the first thing I have to do is assign the PC# to the preset on the PBC....Then I setup the preset..... let's say preset 5 on the PBC is setup for midi preset 5 on the tonal recall, I go to another preset on the PBC, put the tonal recall in the live mode (middle position) make my preset and then while holding down the tap and bypass button I press preset 5 on the PBC...The LED will flash on the tonal recall pedal and the preset is now stored......
It also seems that if there is nothing stored in a preset on the tonal recall it just stays on the previous preset when you go to another preset on the PBC.....Would be nice to have a default of 0 instead of every preset to be incremental....
You can set the cba to "send redundant pc messages" in the device tab and set resend on second preset press.
This will allow you to save by pressing the current preset button while holding the the two footswitches on the cba pedal.
Thanks.....Not sure this will work being that I already have second preset press assigned to amp channel switching.
