Here's a beta version of the 1.3 firmware. Changes for this version are:
UPDATE 9/6/2013
1.3 beta 2 adds the following bug fixes:
Please give it a spin and let me know if you find any issues.
You can download the firmware here:
http://www.rjmmusic.com/downloads/MMGT13b2.rjf
The updated manual is here:
http://www.rjmmusic.com/manuals/Mastermind GT Manual-1.3.pdf
And an updated editor can be found here:
http://www.rjmmusic.com/software/MMGTEditor-1.3.0.dmg (Mac)
http://www.rjmmusic.com/software/MMGTEditor-1.3.0.zip (PC)
Observant readers will note the editor has jumped versions from 0.8.5 to 1.3.0. This is to make it easier to know which editor goes with which firmware - the version numbers will match.
- A complete overhaul of the setup menus. The main reason was to support the upcoming Mastermind GT/10. It also makes the menus more consistent, with a Done and Next Page button in the same location in every menu.
- Kemper KPA bidirectional support. You need to use two MIDI cables from Kemper to GT (input to output and output to input) to get this to work. When connected this way, you will have remote tuner display, better tap tempo support and the ability to download preset names. Also, the Stomp buttons (A, B, C, D and X) will update their names to indicate the type of effect that the button is controlling at the moment.
- Added preliminary (read: untested!) support for Eventide H9 and Gibson Echoplex Digital Pro Plus
- Fixed support for Strymon Timeline and Mobius. Timeline looper support may still need some work.
- Added new button types: Page Down, Preset -, Preset + and Label (a label is a button that doesn't do anything - just displays text)
- Added the ability to send two CCs from each expression pedal
- Added the ability to have the expression pedal's minimum value be less than the maximum value. This allows you to run the pedal in reverse, or cross-fade two CCs by setting one with normal values and the other with reversed values
- Added a Stop button to the preset name read screen, so you don't have to load all 384 presets' names each time
- Fixed weird button behavior after a factory reset
- Fixed a bug that would occur if you had more than 16 preset buttons on a page in Song/Set mode
- Fixed a bug that would prevent momentary buttons from working correctly in IA mode
UPDATE 9/6/2013
- Fixed a problem that made some buttons' on color change when the off color was edited, and vice-versa
- Fixed the Set Default Buttons feature - it was disabling the global setting on all buttons
