JeffMarshMusic
Hi Ron,
Since I purchased my Effect Gizmo and MMGT, I have been enjoying the 2 amp setup as described on page 13 of the Effect Gizmo manual. It has worked great with my Mesa and Fender Blues Deville which can be channel switched with my Amp Gizmo.
I recently swapped my Blues Deville with a Twin Reverb which doesn't have a drive channel. I would like to be able to switch my Mesa to a drive channel while having the weight of the 2nd amp, but I'm stuck with a relatively clean sound on the 2nd amp (unless I have a drive pedal before both amps which doesn't always work with the mesa on the drive channel). What I'd like to try, with your blessing, is have a drive pedal on the Twin only while switching the Mesa to it's drive channel.
At the moment I have my amps in channel 11 & 12 of the Effect Gizmo, and Channel 10 is unused.
Is it possible for me to move the Mesa to Channel 10 of the EG, move the Twin to Channel 12, and insert a drive pedal in Channel 11? My intent would be to have the drive pedal as an option to apply to the Twin only. I know that the last 4 EG channels are different than the first 2 sets of 4. So I'm not sure if the signal will pass through as I hope. Also, the click stopper might end up skipping the drive pedal in Ch.11.
Trying to wrap my head around this and would love your help.
Thanks,
Jeff
Thanks,
Jeff
