2 PBC with Mastermind GT 16
iam want order one PBC now and later one more PBC with Mastermind GT16 or GT22 (iam need about 20 loops) and connect following the way:
guitar - input PBC1 (6 loops non buffer with click stop (for wah, fuse face etc) next loops buffer enable) - output B (or B iso) for Talking Box MXR M222 or Amp with Heil Box HT1 - output A to input PBC2 (all loops with buffer and clik stop; last 3 loops for Strymon pedals with Mission expression pedal connect to Mastermind GT) - output A & B to amps
Iaь have question - Mastermind GT not conflict with two same PBC (jam want controls 2 PBC like one switch with 20 loops) or better order 2 effect gizmo, Y-not and Mastermind GT. May be this better for control and sound quality. In PBC iam like first - watt may buy in parts and all parts work separately and second like enable/disable buffer and click stop from menu without re-wiring
Thank and sorry my english
That should work - the PBC will be able to be controlled by the Mastermind GT or other external MIDI controller if required.
If connect 2 PBC with MIDI cable May iam press preset butom (for example preset 1 on first PBC) and change ( on /off) loops and functions on both PBC's ( without mastermind Gt, only 2 PBC conect together)
It depends on how the two are configured. How would you like it the two to work together?
conect 2 PBC's in serial (output A first PBC to input second PBC), in loops mode iam all understand - 20 button =20 loops. But in preset mode (or song mode), vay iam create preset on button on fisrt PBC and this preset change loops (on/off) on first and second PBC's?
Yes, that seems like a good idea. I'll make sure that this feature is available by the time the PBC ships.
if you may doit that this be great. Because GIGRIG G2 have this function " you can actually connect two G2's together and have one controlling the other. Press and preset on one G2 and choose from the 20 effects loops" (from FAQ G2)
