I'm sorry I've been so silent on the upcoming 4.0 release. It's been a lot of work and I've been at it since June. I probably should have split it into two releases, but too late now! I hope to have a beta release out there before Christmas, and that should be feasible. There's only one moderately complicated feature and a handful of small ones left to do.
In case you're interested, here's a partial list of what's going to be in there. There are no huge "revolutionary" features, I'm afraid, but a lot of smaller things that I hope will be useful for you. A lot of restructuring went on behind the scenes which should make future improvements easier.
- External switches are now able to be specified for each button pages. Preset-level overrides still are available.
- External switches pay attention to the button color settings, at least as much as they can. "Black" means LED off, any other color means LED on
- Presets can have colors assigned to them, which will be displayed when their preset button is selected, overriding the preset button's color
- There's a new "Preset 2nd Press" option: alternate. This allows you to set an alternate preset number for each preset, and a second press on a preset button will recall that alternate preset. Kind of like global preset, but you can have a different alternate preset for each preset.
- A special color can be set to indicate that an alternate preset is active.
- When in song and setlist mode, you can select songs outside of the current setlist and can select presets outside of the current song.
- Function switches now have global and local settings. You can specify a default on or off setting for each switch, and can override that setting on any presets. You can lock the setting on the global level, which sets the function switch to a specific on or off value and won't allow it to be changed. Or, you can select a function switch to be independent, which means that the switch does not automatically change when you change presets, it only changes when you press a button that controls that function switch.
- IA Link now works with buttons that have a System / Preset action (will automatically be highlighted when that preset is selected)
- There is a new Expression Pedal action that allows you to load one of 128 different expression pedal settings blocks on the fly. This replaces the expression pedal grouping feature.
- In setup mode, you can now format a flash drive directly from the LT
- MIDI Forward mode allows you to use the LT as a MIDI interface. This allows the LT to work with the Strymon Nixie editor to communicate with your Strymon pedals.
- New action: System / Song
- System / Setlist and System / Song actions now have "prev" and "next" special values
- MIDI Clock now has an Auto setting, that acts as a slave when a clock is incoming, and acts as a master when there is no incoming clock
- System / BPM action allows you to change tempo on the fly. Special values are "Off" (no clock), "Preset" (use current preset's tempo), "Song" (use current song's tempo), and "Same" (keep current tempo)
- Presets and songs also can use the above special values (where appropriate)
- PC action now has "same" and "previous" special values to resend last sent PC, or to send the previous PC (2nd to last sent)
- There's now a setting to enable sending MIDI Start / Stop messages when the clock starts and stop
- Added a System / IA Store action, works just like an IA Store button except doesn't necessarily need to be held (unless you put it on a Hold button)
- Button name display now has an adjustable time period
- Added a setting to send (or not send) tempo to the MIDI In port's secondary output pins
- Added an "Ignore Preset Tempos" checkbox, when checked, all tempos in all presets will be ignored, using only song or button tempos
- Fixed Strymon CCs
- Added Boss MD-500, RV-500 support
- Added Empress Echosystem, Reverb and Tremolo support
- When switching setlists, will always start at the beginning of the new setlist
That's most of it, a few others will still be added in the next week.
- Fixed Strymon CCs
