I am working out the design of my new pedalboard and am trying to decide which RJM products would best fit my needs. I am on the fence between a PBC/6X plus a Mini Effects Gizmo and a Mastermind LT plus two Mini Effects Gizmo's.
You say the following about the PBC: "The PBC/10 uses relay switching which allows you to use it without any buffers. Matrix switching needs a buffer in front of it when used with a standard guitar."
Which leads me to ask how one would incorporate a Fuzz Face germanium fuzz (JAM Fuzz Phraze) into a system using the PBC/6X?
Also, my amp (3rd Power Kitchen Sink) has three 1/4" jack function switches. So I am assuming that with either the PBC/6X or MasterMind LT I would need a Mini Amp Gizmo since the /6X and the LT only have two function switches?
Basically, I have 13 effects pedals (including a germanium fuzz and a germanium treble booster). Only one is MIDI (Source Audio Collider) but I will want the Collider and my JAM Delay Llama+ analog delay in my amp's effects loop. The ability to switch loop order would be nice so I can move compression, fuzz, and vibe order around in presets. The /6X and a MEG would handle the number of pedals I have using the split mono functionality of the /6X but the buffer question looms. Please advise.
Thanks in advance,
Tommy
ps - you should release "X" versions of the Effects Gizmo and Mini Effects Gizmo that include loop ordering, split mono capability, and the option to use loops as function switches. A Mini Effects Gizmo /X would be killer...
Thanks in advance,
Tommy
