A couple of quick general questions...
Gordon
1. Is there a setting where pressing one button changes the color of another button? I'm using an external switch (no LED) to engage the boost on my JA Broken Arrow overdrive, which sits below a riser. I'm wondering if toggling the boost can change the LED color on the overdrive button.
2. Is there a way to change what page is displayed first when the PBC powers on? I'm often having to cycle through a few.
An IA button can use a Set IA action to turn a button on or off, making that button send its message(s). You can't get to ti just change the color of the button without doing anything else, though.
In the most recent video I did, I show how this is done with two buttons. One of them is an IA cycle button, but it will still apply to two normal buttons. Most of it is about IA Cycle, but I add in the second button toward the end.
IA Cycle Buttons
I'm pretty sure you can use a startup macro to select a page at startup.
Edit Macro 0 in the Macros tab (assuming you haven't used it for something else)
On that macro, add a System / Page action that loads the page you want
In Globals, set Startup Macro to 0.
I think that should do it.
