I've been tidying up my PBC6X layouts to streamline how I use it in a live situation and I'm almost there except for a couple of quirks I can't quite figure out - picture for reference.
I spend most of my time on two pages. A 'preset' page where the bottom row of buttons calls up presets and the top row as IA buttons to turn on different modulation, delays, verbs, etc. The second page is a Loops page which is more or less a stompbox page which lets me turn on/off different gain stages depending on what's needed. I've found this set up is super flexible and allows for quick changes so I'm not locked to whatever the preset is set to.
My 3rd and 4th Gain Stage is handled by The Kilt V2 (in loop 4) which has the normal and red mode - selectable by using the FnSwitch. I've noticed that sometimes when I select a preset that has The Kilt's Blue side active (loop 4 open) and go to the Loops page, the corresponding LEDs for the Blue and Red side are both lit up - even though the pedal remains on the blue side. For me to switch to the Red side I have to double-tap the IA button to close/reopen the loop and switch modes on the pedal. First Question: How do I adjust the PBC6X config so it doesn't think the Red mode is active when it's not? Or to say it another way, how do I make sure the Button/LED status is correct when using multiple modes of a pedal in one loop?
The second question: How do I create a preset to call up the red side of the Kilt? On the Presets tab, I've tried adding the FnSwitch command in the 'Preset Actions' subtab however while it opens Loop 4 it doesn't switch modes.
I've attached the PBC6X Editor file for reference. Appreciate any help to smooth out these two points.
