Great. One question. I want to configure as follows. Each bank will be a preset on the AX3. Buttons 1-6 will select scenes 1-6. To do this I would set the buttons up to select IA's where I would toggle the CC. For the presets I would configure the bank buttons as PC selects. Is this correct? Is there a tutorial that has this kind of setup? All videos I have seen don't cover this kind of functionality.Yes, the LT will support the Axe-Fx III as much as possible. A lot of the code in the two products is shared, so most of the work for the LT will already be done when the GT's support is ready.
Thanks! I will try it.Set it for an "Axe-Fx II XL+ (slave)". That's the closest setting. If you do that, you at least have predefined CC numbers on the LT. You'll have to set the CCs to match on the Axe-Fx though.
How can I implement 2nd press functionality using this mode since I cant specify an alternate preset? What I would like to do is to toggle between the current scene and scene7 using this function. Is this possible? Thanks again for all your help.Set it for an "Axe-Fx II XL+ (slave)". That's the closest setting. If you do that, you at least have predefined CC numbers on the LT. You'll have to set the CCs to match on the Axe-Fx though.
It is my understanding that in this mode each preset is like a song. I use buttons 1-4 to select scenes in the preset. I would like to use the 2nd press function to toggle between the currently selected scene and scene7. If I can use the alternate preset that would be great. I am just not sure how.Why can't you specify an alternate preset?
Doesn't the 2nd press alt preset send a different PC? I would like it to send the current PC with a different CC. Hope that helps.Why can't you specify an alternate preset?
Any update on Axe 3 support for the LT? Are you waiting on having a more complete implementation on the GT to make debugging less complex?
Now that the GT firmware has released, can we expect the LT version soon?I keep having to fix the GT implementation due to bugs and/or changes to the Axe-Fx firmware. I'm hoping to finish the GT firmware very soon, then I can finish the PBC/LT implementation, which is about 75% done right now.
Thanks for the update. Looking forward to the new firmware.It's still not 100% correct, things keep changing on the Axe-Fx side and I have to keep fixing to compensate. I think I should be able to do a firmware release for all current Masterminds after Axe-Fx firmware 1.16 is available.
I just got the LT up and running with my Axe FX 3, love it so far. I watched the tutorial videos and the only thing I can't figure out still is how to download the Axe3 preset names from the unit. I follow the video but it just sits waiting forever for the names to sync up. Probably I have missed a setting on the fractal or something. Has anyone else had this problem and got it to work? Same thing with the tuner, so it seems like bidirectional is not working or something.
