marshall2553
I have one of my IAs set up as a tap tempo button with 'Flash with tempo' checked. Everything works as expected except the LED doesn't flash the tempo until after I tap one in. Is it possible to get it to flash the preset tempo without tapping a new tempo in?
I'm on the latest firmware, I have the Axe Fx setup as described in the manual and I selected Axe Fx 3 as my device on the LT. I'm using two 5-pin MIDI cables from the Axe Fx to the LT. Other things that I would assume use bidirectional MIDI like the tuner display are working fine.
