Here's a feature complete beta test version of 1.4 for you. The changes are as follows:
FEATURES
Bug fixes:
Editor changes:
It's really important that you back up your settings before upgrading!!! This update will modify your settings, so having a backup is insurance against something going wrong.
Firmware:
http://www.rjmmusic.com/downloads/MMGT14b1.rjf.zip
Manual:
http://www.rjmmusic.com/manuals/Mastermind GT Manual-1.4.pdf
Editor:
http://www.rjmmusic.com/software/MMGTEditor-1.4b1.dmg (Mac)
http://www.rjmmusic.com/software/MMGTEditor-1.4b1.msi (PC)
Please test it out and let me know if you find anything!
FEATURES
- MIDI Clock support, both master and slave
- Tempo BPM display on tap tempo buttons
- When tempo changes, it will be shown on the main display for 2 seconds
- Each preset can now have a tempo assigned to it, and - when set to clock master - the GT will start sending the new tempo when the preset is selected
- PC actions can now have a "button on" PC and "button off" PC
- "Preset 2nd press" setting allows you to choose a special action that happens when you press the currently selected preset button a second time. "Preset" is the default and the old behavior - it just selects the same preset again. "Previous" makes the GT jump to the previously selected preset. "Global" selects the Global preset, which is an additional preset designed to be your "go-to" preset that you can access regardless of what preset you're currently on.
- There are new button types: "Page Menu", "Preset Menu" and "Song Menu". These buttons turn all of the GT's buttons into a Page, Preset or Song selection menu so you can jump from one page/preset/song to another quickly
- Changed the Axe-Fx and KPA device settings to have additional "slave" settings. These change how the GT interacts with the effect processors, making the GT in charge of the effect on/off settings instead of the effect processor. I'll have to make a video to describe this feature - it's a useful feature, but hard to describe!
- Changed the "Get Preset Names" feature to have a menu. This allows you to select a range of presets from the device, and select where those presets are copied to on the GT.
- Added (untested) support for Strymon Big Sky
Bug fixes:
- Fixed an issue where the main display could have incorrect pixels here and there
- Made the Axe-Fx device not allow incoming program changes by default - they were often more trouble than they're worth.
- Assigning a default page of buttons now cleans up any "leftover" buttons that might be on the page that could cause conflicts.
- Fixed expression pedal assignments for the Kemper Profiling Amp
Editor changes:
- Lots of changes to support the GT firmware update
- Added "copy page" and "swap page" options in the button page's context menu
- Lots of bug fixes
Firmware:
Manual:
Editor:
