Hi Ron and co., I just wanna say first and foremost that I'm absolutely in love with this unit and its endless customization options. Beautifully designed! I'm so close to getting this stereo rig build I planned for months all set to go.
So basically, I have loops 4, 5 and 6 (H9x2 and a Ventris, respectively) in stereo, and output set to stereo as well. For physical configuration reasons with the underside of my board, I elected to have my EP Booster in the Insert loop since I can obviously move the loop order around per patch.
For both my gritty clean and dirty lead patches, I have that Insert loop placed before the stereo loops. When I turn it on, there's a huge volume drop. Even with the EP Booster cranked. I made a preset that's only the EP Booster and it's the same issue. I have the pedal's internal +3db switch activated, and I've tested it solo with my guitar and practice amp-- it works as expected. Furthermore, I just tested the patch cables I was using (Mogami + Squareplug) and they're totally functional.
What can I do from here? I've attached my settings file. Thank you so much in advance for your help!
