Bigger/better JX44
Discussion in 'Suggestion Box' started by hochha, Sep 8, 2013.
  1. hochha
    hochha
    Jul 13, 2013
    15
    0
    Something like a Radial JX44 but with effect loop selection for each amp feed and amp output muting from the Mastermind GT! The remote pedal board high to low to high impedance feature works well for long cable runs.
  2. onilozer
    onilozer
    Apr 23, 2011
    12
    0
    this is my idea! jk, but yes yes yes on the idea
  3. MartinCliffe
    MartinCliffe
    Feb 2, 2010
    380
    0
    I like this idea. There are some strange design choices on the Radial product... the proprietary footswitches could be replaced by MIDI or standard footswitch control, the low impedance pedalboard run could be done on a single multi-pin cable (5 pin XLR would be fine - easy enough to get hold of the cables), you could happily lose the extra #3 and #4 amp outputs, and it needs to be NOT YELLOW! An effects loop per amp, or at least a couple of switchable loops, could be implemented with TRS to save space. There also needs to be a loop before the buffered pedalboard run so you can patch in a MEG or similar to run those awkward fuzz pedals etc that don't work after a buffer.
    So, 1U rack unit, 4 way input selector with a front panel override jack, pre-buffer loop on the rear panel, front panel 5 pin XLR jack for low-impedance pedalboard run, with breakout box (standard RJM Mini enclosure would be fine - could have a 6 pin XLR MIDI passthru potentially too, to keep things neat). 4 switchable amp outputs, either with independent loops or at least a couple of switchable loops. Tuner mute, switchable via MIDI CC (the ability to route a 2nd signal jack to the tuner out when it's not in use for the main signal would be a boon for guitar techs). MIDI control. Maybe a DI box selectable per input, for acoustic (this isn't a feature I'd be particularly worried about). RJM silver. Call it something like "Matrix Gizmo". Sound good?
    Oh, and less than $1000. The JX44 is cool, but overpriced (as is all Radial stuff)
  4. onilozer
    onilozer
    Apr 23, 2011
    12
    0
    i'd really rather prefer a routing matrix, might have said this prior not sure, but where you can switch 4 amps into 4 cabinets in any configuration, would be cool for my recording "needs"
    thanks
  5. hochha
    hochha
    Jul 13, 2013
    15
    0
    A JX44, JR5, SGI44, SGITX, SGIRX would run about $2400.00 or so. Many of the these technologies seem already present in your product lines. Could the custom shop provide an equal or better item on a semi standard product level. If you could add amp and cabinet matrix switching abilities, what would be the price point. I would rather buy American where possible.
Share This Page
