You have two buttons that control the expression pedal and both will try to select your expression pedal when you change presets. So, if you have "Boost Exp" turned on but "Exp" turned off, the first button will select setting block #2, but the second button will select setting block #0, overriding the first button.
I recommend setting both buttons to Group 1. This will prevent both buttons from being turned on at the same time. Also, in the Globals tab, select group 1 and turn on "Allow all buttons off" and turn off "Send off messages". This will insure that only one of the two exp buttons sends its messages every time you change presets.
