EVHGuy1111
I am a bit confused.
I know where to put a BOOST pedal for solo volume boost without adding pre-amp gain on a mono rig... it goes in the effects loop (usually the last in the chain).
But where do I put the BOOST pedal on a WET/DRY rig to boost both amps equally during a solo boost? And if I am using an Effect Gizmo or MEGX does this add to the complexity when running Four-Cable-Method for a WET/DRY rig?
