Stratman2003
I just got my Mini Amp Gizmo + RRN Cable, and had the Boss GT10 changing channels in 10 minutes. Now I use the GT10 with the 4-Cable Method, which allows me to contrast the various GT10 OD/Dist options with the Nomad seamlessly = no tap dance!
I would like to use one of the GT10's Ctrl FtSw to toggle the Nomad's Solo function as well.
1) I set GT10/Ctrl2 to send CC Out msgs on #93= Mini AG sw6 = Nomad Solo Function
2) I set GT10/Ctrl2 "Src Mode" parameter to "Toggle"
Manually, the Mini AG sw6 Toggles the Nomad Solo on/off. Unfortunatley, when using the GT10/Ctrl2 it just acts as a Momentary switch, only activating the Mini AG & Nomad Solo function while the GT10/Ctrl2 FtSw is depressed.
I also tried setting the Mini AG sw6 to "momentary" and correspondingly set the GT/Ctrl2 to momentary also. In this case they do work together, but again, only as a momentary switch.
This is driving me crazy.... any help would be appreciated.
