Hi Everyone,
So I have my board all setup - all pedals / loops working great. I have one issue though that I cannot seem to solve. I'm running a Boss MD-500 ( Pre / Post ) -not in loops. So output A of the MD 500 runs into the PBC In 1-4, and coming back into the MD500 Input B from the effects send, Output B runs into In 7-10 --Perfect all is good. The pedal functions as it should , manually switching between preset A and B. I'm trying to figure out how to turn the MD500 on and off via MIDI per PBC preset. Using the PBC Editor I have my MIDI devices all setup. On the Presets/Presets Action Page I setup CC's as I saw one person showed how to do in another thread and it did not work for me quite as expected, so I'm assuming I'm missing something else either in the PBC editor or in the MD500 settings. \
What ultimately happens is this- preset A on the MD500 turns off (as I want it to) when changing from PBC preset1 to PBC preset 2, BUT it automatically toggles the MD500 Preset B on. This is what I do not want. When I switch to PBC Preset 2, I want both A & B on the MD500 off. Does anyone know how to make this work? I did have it working briefly ( and yes, my midi cables are good). What I initially did was this:
MD-500 Effect A on / CC Toggle# 28 on:127
MD-500 Effect A on / CC Toggle# 28 on:0
MD-500 Bypass / CC Toggle #27 on:127
MD-500 Bypass / CC Toggle #27 on:0
I originally tried the first two CC's as another member pointed out. That just switched A of and B on. Once I added the last two CC's, where CC#27 is the bypass state for preset B it seemed to work, but I made a simple change on the devices page to the bank type and it stopped working. Even after I changed the bank type back, and transferred the changes, it still still didn't work. Just FYI - my settings on the MD500 are set to the proper midi channel and I'm using the MD500 in normal mode, so no instances of ever using both A & B presets at once.
I'd appreciate any suggestions.
Thank you,
Mark M
Thank you,
Mark M
