Even though I will probably just call Ron on this one tomorrow afternoon, I thought it might be helpful to post this for Troubleshooting purposes. Just in case anyone has, had, or will have this problem.
This never happened before but I also just started running this rig at stage volume. I run a pair of heads using the isolated loops. I have never run into a ground loop yet and running to both the lo and hi inputs on both amps has never been a problem. But the other day I started to get this rig ready for live use. I am using a Dr.Z RX and a Bogner XTC. I had no problem what so ever cranking the Z. But for some reason the XTC starts squeaing like crazy on either hi or lo inputs.
So I thought it might be the order (not that it should matter because the loops are isolated right?) and began switching the input order. Nothing. Then I thought it might be a problem with having the lo and hi patched (not that I ever run them at the same time). Nothing. Then I start to think I have a microphonic tube. I just had this amp retubed and biased not that long ago and I haven't run it that hot in that time. So I pull the XTC from the RJM and run straight to it. Guitar > Cable > XTC........ No squealing. Sounds fine. I crank it a bit louder. Fine.
I'm just wondering if anyone has had this occur. I find it hard to believe it's the Effects Gizmo because the Dr.Z runs like a champ in both lo and hi through it's respective loops, but my XTC squeals in the loop but not direct from the guitar.
Any answers??????
Any answers??????
