Button display suddenly blacked out during practice.
Megahertzz
The unit has very little use, and only been powered on 2 or 3 times the last 3 years. It has always been kept dry and warm indoors, never spilled or dropped anything on it.
Is there any way to fix this that doesn't require sending it to the US and being without a pedalboard for several weeks?
Does it look like that when the button is not active as well? And, how old is this GT?
Megahertzz
I haven't gotten the chance to check if it's the same when there's no function assigned to it, but it's the same when waiting for the Axe FX III to boot up and connect. It was ordered June 7th 2019. Order# 4845.
Ok, then the easiest thing to do is to sell you a replacement circuit board for the lower row. Replacing a row is fairly easy, just unplug a cable, remove some screws, swap circuit boards, then reverse the process. Please contact me at support@rjmmusic.com if you'd like to go ahead with it.
