I have a Rack Gizmo & am looking at p12 of the manual where it states:
1. There is a mono to stereo converter cable between loops 6 and 7
2. there is a shorting plug (a plug with tip connected to ground) in the Return 5 jack
Asking if someone can explain all the wiring requirements to make these up?
1. How do i make a mono to stereo converter cable?? TS on 1 end & TRS on the other?? Do I solder the tip cable on the TS side to the ring & tip connectors on the TRS side??
2. the shorting plug is a plug with tip connected to ground; where is the ground on a TS plug & what do i do with the 'sleeve' connection?
Can i buy any of these from RJM??
Thanks in advance.
Thanks in advance.
