wire_twerp
Hi there
I need a little help please.
I'm using two high quality 5 pin midi cables to connect direct to the FM3 from the PBC.
I have the FM3 set up as a device with MSB, flat numbering, max presets 512, max PC 128, PC offset to 1 (I tried to upload the RJS file but the browser applet keeps telling me the file is empty, which it isn't).
For example, I am trying to select preset 002 (of 512) using an IA Test button (see page 1) and also recall the same on the PBC. I would have expected that to get to the first FM3 bank (which would be Bank Zero?), one would use CC#32, off=none and on = 0, followed by the relevant PC command (=1). For the FM3, this assumption seems to be correct.
So, when I execute this command, although it correctly selects Preset 2 on the FM3, it selects Preset 514 (not 002) on the PBC! Thus, I cannot access presets 1-128 in conjunction with the FM3 when using the PBC.
Furthermore, if I use the Bank UP/Bank DOWN buttons, I cannot get below Bank 9 (on the PBC display), although this does allow me to access Preset 1 on the PBC but not on the FM3 - it will not let me go lower than FM3 Preset 7.
Secondly, I cannot get the PBC to read the Preset Names on the FM3 no matter what I do.
I do not know what it is happening here and I would be grateful for some help. Thank you.
