ANASON Records
is there a way to make this happen:
i am using the GT16 simultaneously to control Axe FX 3 and ableton live 11. Both are listed as different devices under Devices menu so there is no risk of sending same midi message/command to both devices accidentaly.
I have 3 expression pedals attached to Gt16 which control normaly things in Axe FX like wah, whammy, fx mix etc. Than i have an IA it changes all the pedals to CC's that control Tape Delay in Ableton. Which works great, no issues. But if i go full on with the tape delay's repeats (modulated with 1 of the expression pedals) and turn the IA off before going down with the repeat rates, this can cause accidents on stage....where the repeats oscilate and peak. Is there way to make the expression pedal send a certain/set value going back to the regular expression pedal number? (for that IA's off state) I tried smth similar by adding a CC command but i think the expression pedal is over writing it and it did not work.
Hope this is not too confusing and i was able to explain the case...thx
