Meanoldfireman
I'm setting up a GT 16 as part of a backup/downsized rig. (Main rig is a 22).
I have loop in an effects gizmo set up as an IA to control a Leslie Digital pedal. I'm also using the relays in a G-Major 2 to control the Speed and brake functions (the pedal is digital, but not MIDI). Since I only use those when the Leslie is active, I don't to dedicate IA buttons to them on the main button pages, so I I'm putting them on the local page for the presets that have the Leslie active.
I want to be sure the loop controlling the Leslie is shut off when I switch to another preset. but since the button isn't on the other pages, I haven't come up with a good way t do that.
So far, the only thing I've come up with is creating a Program in the Effects gizmo that has all loops off. If I put the PC message for that Prorgram for the other presets, that will clear everything before the CC's assigned to that preset are transmitted?
If there's a simpler way to do this, let me know.
Thanks
Ned
Thanks
Ned
