Clock output on PBC6x
Is there any way to limit the clock output from the PBC/6x to just when you change a song? With it set to transmit, it runs the clock output continuously and shows up as a (albeit low level) hash noise on the amp (which has MIDI control). Maybe I'm not understanding this correctly. Thanks
If you're getting noise, that typically can be traced to a MIDI cable that isn't shielded properly, or in some cases, can be traced to a ground issue. In the rarest cases, some MIDI enabled pedals have some bleed between the MIDI signal and audio. Going through your rig and figuring out where the noise is coming from and/or measuring your cables to see if they're properly wired are good ideas.
MIDI clock is supposed to be continuous, per the MIDI spec. The intent for this is to keep multiple devices in sync with each other at all times, so they can't drift apart.
That said, the continuous clock requirement makes more sense in the synth and sequencer world than it does in the guitar effect world. And, clock synchronization issues were more prevalent in the old MIDI days when computer hardware wasn't as good as it is now. As of firmware version 5.2, there's a "Clock Pulse Limit" parameter in MIDI Settings that lets you set a limit to how long the clock runs each time the tempo changes. Set that to 10 to try it. You may have to add more if your pedals aren't syncing up, or you might even be able to reduce the number, depending on your hardware.
More questions: if I set it to non-continuous MIDI clock (say 50 messages), when is it supposed to send the update to the bus? I noticed that it seems inconsistent (I can see it on my Strymon Conduit). My Strymon Volante doesn't want to respond all the time because it only seems to pick up the tempo when I change presets (on it). I am a little confused. I'd like to run the clock so that it only sends out a burst on a song change. The amp seems to pick up the noise when it runs continually...
I want to understand clearly how this works. I have a setlist with 5 songs (each with at least 4 presets), with tempos 77, 76, 56, 75, and 108. From your description, shouldn't the clock pulses go out every time I change songs? I do not see that behavior. Sometimes, it does when I change songs, sometimes when I select a certain preset in a song, sometimes not at all. Please elaborate - thanks!!
I had a look and the condition is "send pulses if the BPM change is greater than 1". So, this could prevent tempo changes when switching between BPMs of 75, 76, and 77. For the next release, I've changed the condition to be "greater than or equal to 1", which makes more sense to me.
