Thanks--just ordered a chase bliss.If you use a Chase Bliss or Disaster Area MIDI Box, you can connect it to both the Iridium and also use the MIDI Thru port to go back to the PBC.
I've got it hooked up, and I think it's working, thanks for the suggestion!Thanks--just ordered a chase bliss.
I’m also wanting to do this with my 6x. So would I just need the chase bliss midi box and would I need a certain cable for the iridium? I have a collider and terraform connected midi now.If you use a Chase Bliss or Disaster Area MIDI Box, you can connect it to both the Iridium and also use the MIDI Thru port to go back to the PBC.
I managed to get the PBC to work with my Iridium by connecting a simple 5-pin-midi-to-TRS cable however, this only worked for a direct connection from the PBC's midi-out port to the Iridium. This solution failed when I attached the 5-pin-midi-to-TRS cable to the midi-through port on my Eventide H9. When putting the H9 in the loop, the Iridium failed to respond to any/all PC or CC messages...
Even weirder is that I can't seem to get the simple 5-pin-midi-to-TRS cable solution to work when I set up bi-directional midi on the PBC and set the Iridium, in the device setup, to use the midi-in port and connect the cable there. The simple 5-pin-midi-to-TRS cable only seems to work when connected solely to PBC's midi out port.
The midi-TRS cable needs to incorporate the opto-coupler that is a part of a standard midi input circuit. Strymon have released a circuit diagram that shows how their own cable works:I managed to get the PBC to work with my Iridium by connecting a simple 5-pin-midi-to-TRS cable however, this only worked for a direct connection from the PBC's midi-out port to the Iridium. This solution failed when I attached the 5-pin-midi-to-TRS cable to the midi-through port on my Eventide H9. When putting the H9 in the loop, the Iridium failed to respond to any/all PC or CC messages.
This confuses me because I know the H9's midi-through port is working. I set up another midi device connected to the midi-through port and had no issues controlling the second down-stream device.
I assume the correct solution is to get a midi box either from Disaster Area or Empress but I'd love to understand why.
Hey! Did you ever figure what dip switches need to set to? Thanks!If I we’re to snag the Midi Box 4, anyone know what dip switch settings I would use for the Iridium?
hint - the dip switches are two positions. I have one and set port 1 with dip up and port 2 with dip down. I then saw which one worked and made the rest match. Took about a minute and works like a charm.If I we’re to snag the Midi Box 4, anyone know what dip switch settings I would use for the Iridium?
