shoelesscraig
I have a specific issue with MIDI that only happens occasionally. Most of the time (like 95% of the time) my board is powered up and runs perfectly. However, that other 5%, I'm having a strange MIDI issue. I power up the board, everything boots up, and then ANY preset change I make on the PBC causes my BigSky decay to get changed. Doesn't matter what song/setlist/or preset I choose, it will command the BigSky decay (CC17) to be set low...specifically this last time, it was being told to go to 20 (between 0-127). I'm not sure if that "20" is always what is sent when it happens, but this last time it was.
Ron, I know you're going to ask...I know that it's doing the above because I hooked up MIDI-OX while the issue was happening and can see it. However, there are no buttons on any page I have that perform that command, so it's not that. Cycling the power on the PBC causes it to go away, and it will not return again until it's powered down and back up (and even then, the chances of it happening are slim).
I did discover today that when the issue is happening, and I make ANY change in the editor and "write changes to PBC" it will cause the issue to go away. If I had a button somewhere that was doing it, cycling power or "writing changes" wouldn't cause it to go away.
Any ideas? I'll post my file just in case someone cares to look.
