Wheresthedug
I have just added a Whammy DT to my board. At the moment it is placed in front of the PBC (not in a loop) although that may change in future. I am using Midi to select program changes on the Whammy on Midi Channel 4.
Is there a quick and easy way to tell all presets to Default to sending a CC value that put the Whammy in bypass state unless I manually override this when creating a particular preset? Something similar to the default status for loops and switches in the Audio Tab.
I know I could set up a command that sends a default CC of say 23 which is Whammy Octave Down in bypass state but will this still send and override the desired preset say CC2 which is the same preset but active?
