Delay in audio when toggling Output B/Right
Derek McCarthy
I have a stereo setup and have been noticing a delay when toggling Output B. When I toggle Output A on/off the response is immediate. When I toggle Output B on/off there's a noticeable delay in signal. In an effort to rule out the cable and amp I swapped output cables between A and B to see if the behaviour follows and it doesn't...
I've also upgraded to the latest firmware and no change in this behaviour.
Any advice would be much appreciated.
You're probably running into the hold function on the Output B button. If you hold the Output B button, it inverts the phase of the output. When a button has a hold function on it, it doesn't do anything until the button is released (or has been held for a long time). Normal (non-hold) buttons act immediately when pressed. That difference in timing is noticeable.
If you don't use the invert B function, you can edit the button and switch its mode from Hold to Normal. That'll make it work like the other buttons.
