Do I need a SPLiTTER?
EVHGuy1111
I'm slowly building my WET/DRY/WET Rig.
I understand that I need to send my WET effects (chorus, delay, Reverb, etc.) from:
MEXG > Line Mixer > WET AMP Right effects loop return
--> WET AMP Left effects loop return
...for the stereo effect of the w/d/w setup.
The delay pedal I use is mono... but I want stereo. I figure I get 2 identical delay pedals, set them slightly different then their sends will go to the R/L stereo inputs of the line mixer just like the stereo signals of my chorus and reverb and other time based effects.
MY QUESTiON:
Do I need a signal splitter box of some kind in between the stereo output of the MEGX to the 2 Delay pedals? Or since I'm outputting from a stereo output on the MEGX will everything run the same with 2 different pedals as if it were a stereo pedal if I use a Stereo-Y cable from the MEGX > Delay Pedals?
Only insert or stereo Y cables are needed, two identical mono pedals will behave the same as a stereo in / stereo out pedal, as far as the MEGX is concerned.
