[DONE] Global Tempo
Discussion in 'PBC Wish List' started by Kamil Rustam, May 17, 2017.
  1. Kamil Rustam
    Kamil Rustam
    Aug 25, 2016
    50
    5
    It would be nice to be able to set a global tempo that would stay for each preset as long as you don't have a set tempo programmed in the preset
  2. rjmmusic
    Staff Member
    Jan 18, 2010
    6,411
    1,158
    This is another case where it worked that way until someone requested it work differently. Specifying a 0 tempo means no tempo is set. However, there is an undocumented feature - if you set a preset's tempo to 1, it will keep the clock running at its current rate when the preset is selected.
  3. Kamil Rustam
    Kamil Rustam
    Aug 25, 2016
    50
    5
    So if all my presets are set to 1 .... what tempo is it gonna play since no initial tempo is set ? ( I guess I will experiment and find out )
    thanks
  4. Kamil Rustam
    Kamil Rustam
    Aug 25, 2016
    50
    5
    I tried and I guess since there is no tempo outputted , the tempo is whatever each pedal's preset is ... so no sync between the different pedals until I tap something ...
    Global tempo (with a possibility of disabling if people don't like that ) would be great..
  5. rjmmusic
    Staff Member
    Jan 18, 2010
    6,411
    1,158
    This is more or less fixed in 4.0 - there are special tempo values where you can tell a preset or song to remain on the same tempo when the preset or song is selected.
    You can use the Startup Macro feature to call a macro that runs a BPM action to set a default tempo on powerup.
  6. Kamil Rustam
    Kamil Rustam
    Aug 25, 2016
    50
    5
    So, without taking too much of your time, how would I create a startup Macro to have the PBC default to 120bpm at startup ?
    Thanks in advance :)
  7. rjmmusic
    Staff Member
    Jan 18, 2010
    6,411
    1,158
    Edit a macro, add one action:
    System / BPM: off:Same on:120.0
    On the Globals page, set the Startup Macro parameter to the number of the macro you edited in the previous step.
  8. Kamil Rustam
    Kamil Rustam
    Aug 25, 2016
    50
    5
    That works perfectly .. thanks
    BTW i noticed a small graphic bug it seems ( When I tap the tempo)
Share This Page
