Kamil Rustam
So I have been programming all sorts of setting on my PBC and I noticed that the Dry/wet switch would not work ... after trying all kinds of settings to try to make it work I decided to reload a setting I had from a few months ago (That I know worked then ) so when I load that one into the PC Editor and send it to my PBC it works fine .. so I tried to copy the setting inside my new setting but I noticed that the button settings is as follow:
Audio/Signal#2 off:OFF, on:ON
in my new setting I can only access Audio/Signal#1 which doesn't activate the dry signal
then I realized on the original (Working) Setting that if I try to access the settings of that button, it switches to Audio/Signal#1 and when i send it again to my PBC it again fails to work
what is going on? am I doing something wrong? (Probably) or is that some kind of a bug?
I uploaded a screenshot of the setting that works but that I can't recreate
Thanks for your help
