Effect Gizmo loop 12 working in reverse?
gary77
Hi, I've recently brought an Effect Gizmo from eBay and have noticed loop number 12 is working in reverse... the loop is active when the front panel led is off and visa versa. I'm assuming its not just me and it shouldn't be this way? All other loops function as expected... active when led lit. I've disconnected all gear including midi controller to test. At switch on I can hear the relay switching sound, i'm wondering if this is correct or if this mine already selecting loop 12? The loop is perfectly functional I just need to get my head around it being on when the led is off! Any ideas? Regards, Gary.
loop 12 has been switched to onvert mode
hold down loop 2 button whilst powering up the effect gizmo you will probably find when you do this that loop 12 is illuminated
press the loop 12 button to turn the lamp off and then press write to save the setting
loop 12 should now wok the same as all the other loops
no problem you are welcome if you ever need a loop to work in reverse loops 9 thru to 12 can be switched following the proceedure above
