Using loops 1 thru 4
5 thru 7 and #10 in the amps f/x loop.
Plug amp into "output5-8" or CS out.
Plug in a Korg rack tuner and get nothing but added noise.
Ok, you'll have to route your signal through the buffer to get any signal out of the tuner output. Otherwise. you'll have to connect a loop send to the tuner input. That'll allow you to use the tuner when the loop is activated.
Ok, figured that it was internally bridged.
I must have a grounding issue then with the tuner that I have never had before.
Already tried the "lift" on the Effects Gizmo with no change in noise.
...79 cents are now .90 cents. I haven't bought one of those in so long. Older houses over the years with 2 prong wall plugs
made me buy a few handfuls of those things
