I've got a Decimator Pro Rack G setup for 4CM through the Effect Gizmo with a Marshall head. All 3 ground lift switches on the Decimator are on, but i'm still noticing some hum that seems to be caused by the Gizmo's own power adapter.
If i move the adapter close to the Decimator connections it amplifies the hum...so this highlights the cause of the problem, but even if i move the adapter further away from the rig there is still a small amount of hum.
Are there any alternative UK power supplies that work with the Gizmo that could eliminate the problem or is there another way to stop the cables from picking up the hum? I'm using George L cables.
