MuntedFunkster
Hi
Great forum, great gear Ron!! Im about to purchase an Effect Gizmo soon for the stereo rig ive been slowly building... I just have some questions (forgive my newbie dumbness!
regarding the Tuner output on the effect Gizmo... Does this loop the guitar signal out through a tuner and then back into signal chain on the gizmo, or is it just a copied "split" of the guitar signal that routes out to the tuner only?. Im just trying to determine if I should get a high quality rack tuner rather than a cheaper one.
Also, I will be hooking a eventide H3000 harmonizer through the Gizmo.. the H3000's are stereo units and run off XLR balanced (+4dB) outputs. Has anyone used a H3000 with an Effects Gizmo yet? I will be making the cables myself out of Canare cabling/switchcraft connectors etc, however is it possible to connect the two balanced XLR outputs from the H3000 to a stereo TRS connector for the Gizmo? My signal flow will be as follows:
Guitar --> Sennheiser EW300 Wireless Unit---> DimeWah---> Marshall JMP-1 Preamp (dBX compressor in stereo loop) -----> GMajor/H3000/GMajor2 (switched in by the Gizmo)---> Marshall 9200 stereo power amp ---> 2 x Peavey XXX Cabinets
Im also looking at getting the line mixer later on to run a parallel delay from the Gmajor.. I've heard talk of phasing problems that reduce tone with the parallel setups? anyone experienced this or are the line mixers the best option for spillover delays?
Thanks in advance
Cheers
MuFu
Thanks in advance
Cheers
MuFu
