aslak
Hi, I'm rookie here and new Effect Gizmo owner (still waiting product).
I don't understand perfectly how buffer works, when I need and when not.
I use Tuner from tuner out.
Do I have then run buffer all preset so I can tune at any time?
What about if I have few activated buffered pedals in preset with internal buffer -> tone suck?
Is it bad thing if I have few buffer in signal, what you recommend?
Could you check my upcoming setup is there something total wrong
or what I can cabling different or better (attacment file).
  • RJM Effect Gizmo setup.pdf
You do need to use the buffer to get the Tuner Out to work. The buffer should not cause a problem when used with your buffered pedals, but you could try it in a loop as you've done in your diagram. That way you can switch it on and off and hear for yourself whether your tone is better or worse with the buffer. (It'll probably be the same, maybe even a little better with it, I'm guessing).
The diagram looks good to me, by the way.
