Effect GizmoV1 clickstop failure
Walch192
Hi,
I’ve just bought a V1 EG. It’s finally dealt with the digital noise / ground loop issues I’ve have for years with a homemade MIDI loop switcher. Only issue is the clickstop circuit doesn’t work.
I’ve read all posts on the forum, I measure 50ohms between tip and ring on the CS output so assume I need to replace the JFETS in the circuit? Should I use the existing part, or the J111 type mentioned in another forum thread. I wasn’t sure if these referred to the V1 or V2 circuit.
Thanks.
It's almost certainly the FET. For the original Effect Gizmo, P1086 is the FET you should use.
