Nomadicarts
So I’m at a standstill and am not quite sure what my routing options are for this. Ive got a mini effect gizmo with a compressor and an overdrive in the first two loops running to the front of my kemper. These work fine. In the next two loops I have an eq and an eventide H9 which i want to run into the mini line mixer and then into in the kemper effects loop. Here’s where the problem is. No signal coming through at the moment and I'd like to use my empress buffer for the pedals in front as well as those in the loop rather than the one in the MEG.....I like the signal indicator LEDS on the empress- can take the a little bit of the guess work out of finding a bad cable in the chain in the event there is one.
Ive attached my crappy drawing of how i thought things should’ve been wired (and currently are)...but again still nothing happening in the effects loop with this one. Also attached is empress’recomendation for wiring the buffer for pedals in front of the amp as well as those in the loop. Any suggestions on how to make this work would be a HUGE help. Does there need to be something plugged into the returns on the MEG when using the MLM?
