Hey all,
I am modifying a pedal that has a boost function so I can control it with the EG much the same way I do with my amp. This requires a relay, a jack input, some cable, and a bit of wiring. The relay going into the pedal needs to match the voltage from the EG, amps are already set up for this but since I am starting from scratch...
What voltage does the EG put out to switch channels/functions on amplifiers?
Cheers
Cheers
