EHX 8 Step not sending full value
boutte
Hello! I've just noticed a problem with sending the CV output of an 8 Step through my GT 10. I've got the 8 Step running into an expression jack on the GT10 and then sending that via MIDI to various pedals. Previously it was working as expected, with a reversed TRS cable, but now it's only sending a limited CV range. For example, on an H9 preset that has the expression range on a parameter set from 12 to 75 - it only moves from 12 to about 26 when using the 8 Step?
Things i've tested are:
1. updated tot he latest firmware on both the GT10 and the H9
2. factory reset on the 8 Step
3. tried different ports on the GT10
4. plugged the 8 Step directly into the H9 and it acts as expected
Any thoughts on a setting I'm missing or something that may have changed in a recent GT update? Thanks!
