ANASON Records
my expression pedal 1's global setting is "Ext Ctr 1" to use with Wah block in Axe Fx3. Somehow when i go to a preset(try nr 1) something changes it to a stored setting. had to program a second command for the Wah IA so it not only turns on off the block but sends a system command to set expression pedal 1 to its global value. expression pedal 2 and 3 work just fine.
checked every button, setting, i can't figure out what causes this. if someone wants to check my settings, programming.. file is attached, thx.
