ZappaFrank
I have read those things above about Program Changes, but I don't understand it completely. Let's say I have a very simple MIDI Device which is only able to send MIDI Program Changes from 0 to 127 without any other options to define MSB or LSB. The MIDI Mouse comes to my Mind as an example for such a device.
www.thomann.de
So when the MIDI Mouse sends Program Change 1 from its MIDI OUT to the MIDI IN of the PBC10 will the PBC then go to Preset 1 or Preset 2 or is the whole thing more complex and it doesn't work like this?
In normal bank and preset mode (no setlist active), the bank MSB, LSB and program numbers are combined to create the desired preset number. The formula is:
Tech 21 SansAmp MIDI Mouse
Tech 21 SansAmp MIDI Mouse, Midi Leiste mit Up/down Taster einfache Handhabung, auch Batteriebetrieb möglich
There are only 768 presets within the Mastermind GT, so only bank numbers 0 through 5 are valid. The Bank MSB should always be set to 0 (or not sent at all), and Bank LSB should be 0 through 5.(Bank MSB x 16384) + (Bank LSB x 128) + PC number = preset number
