scenesfromahat
So my MM PBC is still on the 4.0-Beta and apparently has the BootLoader 1.1, if that makes a difference. I have the RJM flash drive with a single rjf file on it (MM413.rjf) and I can't get either update method to work. If I power up to the BootLoader and plug in the flash drive, the screen says that it can't find a valid file, and that the system (factory?) file is _MM311.rjf. If I try to go through the menu, I get into System Functions and then can't scroll past "Save Settings." I see that the other options are there (Init Preset Names, for example), but I can only select "Load Settings" or "Save Settings." This happens whether or not there the flash drive is plugged in.
What am I doing wrong?
