Firmware version 1.3 is now available! Changes for this version are:
UPDATE 9/23/2013:
Version 1.3.1 fixes a bug that would prevent you from adding more than two button actions to a button in setup mode.
UPDATE 10/3/2013:
Version 1.3.2 fixes a bug that prevented expression pedal grouping from working correctly.
UPDATE 10/21/2013
Version 1.3.4 fixes a bug that prevented external switches from working in the "Edit Buttons" screen
It also adds a new parameter "Auto Page", that enables or disables the automatic button page switch that happens when you select a new preset
UPDATE 10/24/2013
Version 1.3.5 fixes a bug in button grouping
Here are the download links:
Firmware V1.3.5
Manual V1.3
Editor V1.3.1: Mac OS X / Windows
- A complete overhaul of the setup menus. The main reason was to support the upcoming Mastermind GT/10. It also makes the menus more consistent, with a Done and Next Page button in the same location in every menu.
- Kemper KPA bidirectional support. You need to use two MIDI cables from Kemper to GT (input to output and output to input) to get this to work. When connected this way, you will have remote tuner display, better tap tempo support and the ability to download preset names. Also, the Stomp buttons (A, B, C, D and X) will update their names to indicate the type of effect that the button is controlling at the moment.
- Added preliminary (read: untested!) support for Eventide H9 and Gibson Echoplex Digital Pro Plus
- Fixed support for Strymon Timeline and Mobius.
- Added new button types: Page Down, Preset -, Preset + and Label (a label is a button that doesn't do anything - just displays text)
- Added the ability to send two CCs from each expression pedal
- Added the ability to have the expression pedal's minimum value be less than the maximum value. This allows you to run the pedal in reverse, or cross-fade two CCs by setting one with normal values and the other with reversed values
- Added a Stop button to the Get Preset Names screen, so you don't have to load all 384 presets' names each time
- Fixed weird button behavior after a factory reset
- Fixed a bug that would occur if you had more than 16 preset buttons on a page in Song/Set mode
- Fixed a bug that would prevent momentary buttons from working correctly in IA mode
UPDATE 9/23/2013:
UPDATE 10/3/2013:
UPDATE 10/21/2013
UPDATE 10/24/2013
Firmware V1.3.5
Manual V1.3
