Did it give the same results? Begins the update, but immediately resets?That does not help unfortunately
Yes it didDid it give the same results? Begins the update, but immediately resets?
The input buffer is between the main input and loop 1.The input buffer is located after loop 4 right? The fuzz pedal in question is a Kingtone minifuzz v2. I don’t know if the pedal matters to reproduce the problem
Every loop has its own relay, and the buffer has a relay. The buffer relay would affect the fuzz, no matter what loop it's in, except in the case where the guitar signal comes in after the buffer (which is why I had you connect the guitar to In 5-6 for one test)Well, because of this problem I found out that my unit couldn't update. I already received a brand new unit, and I still have this buffer problem, so it is probably unlikely that I've had two units in a row with a faulty relay. By the way...I changed my fuzz from loop 4 to loop 3 this morning, and I still have the same issue. Every button has its dedicated relay, right?.
