victorymusician
I am having problems putting my mini amp gizmo into GCX mode. any help is appreciated.
The Ground Control Pro foot controller can control up to 4 different GCX units, as long as they're assigned a separate GCX number (basically changes the MIDI CC #s that correspond to each loop). It's just the way of telling it which unit is which.aalev123 said:okay - stupid newbie question - what is the gcx number even referring to?
I think so, yeah. I've not got a Ground Control myself, and it's a couple of years since I looked at one, but I believe that's the case if you're using the Amp Gizmo in GCX compatibility mode, rather than using Program Changes and the built in patch storage on the AG.aalev123 said:so if i have a real gcx but it is handling f/x then the amp gizmo has to be seen by the ground control as "gcx #2" ?
If you have one or more GCX Guitar Audio Switchers, you must enable them here. The Ground Control Pro can control up to 4 GCX units to provide any combination of 32 audio loops and switches.
Enter Setup mode by pressing both [SETUP MODE] buttons at the same time. Then select this category by pressing [EXPANDERS].
To enable the GCX, press [+/YES] to turn GCX #1 on. If you have more than one GCX, press [SELECT 2] to access the next GCX. You can continue to enable GCX units 2 through 4.
