Matt Bender
Back in Oct I posted about having issues trying to setup an IA switch as a boost/solo switch. At the time, I was having some 'Ghosts in the Machine' type issues (my external expression pedal #1 wouldn't work, but the others did) so I did a factory reset and reload which fixed the pedal issue and I finally got it to work...sort of.
The way I got it to work was to assign the IA switch and Axe FX Output#4 both to CC#7 and set the off and on values accordingly in the Mastermind GT (interestingly, this wouldn't work when I set them to the value to the sys ex value in the editor (CC#45=Output#4) but it's working with #7 so I care less about that now).
My issue still is that if I engage the Boost IA switch and either select another scene or pick another preset the value doesn't return back to the 'off' value with out me manually cycling the Boost switch on/off again. I'd prefer it to just go back to the default value of the IA switch being off and sending the corresponding off value to the Axe FX. I have the 'Update on Preset Change' box checked in the IA settings and the 'Global' box in General Settings is checked too. Is there something else I need to do to get this to work?
Thanks,
Matt
Thanks,
Matt
